lamp colours
- greenglade
lamp colours
Hi all
I've just been preparing the lamps on my Gresley A1 model and while looking at pictures of tenders noticed that the lamp body isn't white?..can someone confirm this please, I had thought that the bodies were white with clear lens at the front and red at the rear, I'm not so sure now hence my question to the experts, are the tail light bodies red as well as the lens?...anyone is an expert in this area when compared to me so will bow to your knowledge folks...
Over to you guys...
Pete
Over to you guys...
Pete
Re: lamp colours
Standard pattern loco headlamps were white bodied with a clear lens and a red shutter which rotated in front of the burner. At grouping the lamps of GN origin were black and became white in time. The other pre Group companies had their own patterns which disappeared very gradually.
Tail lamps were red bodied with a red lens until the advent of ARP regulations in the late 30s when they became white with a red lens, except brake van side lights which were a bit more complicated, but generally had black bodies and both red and white shutters.
- greenglade
Re: lamp colours
thank you for that informative reply 2512...do you know of a photo of such a lamp either alone or fitted to a tender/...I have just been looking through my various books and had noted what I think are both colours....
This photo of 4472 in July 1938 looks like it's showing red....do you by chance know the cut-off date of when they changed it to white...I guess this may have taken some months if not years before being fully implemented? i ask as I'm modelling in 39...although my window could be 38 to 43 if pushed...
Oh, and what's ARP?
cheers
Pete
Oh, and what's ARP?
cheers
Pete
Re: lamp colours
Air Raid Precautions - blackout and suchlike.
- greenglade
Re: lamp colours
Re: lamp colours
The first image is the standard loco headlamp in use up until about 1935 after which the cowl was removed. This lamp had a red shutter inside and could be used as a head or tail lamp.
The second image is a typical (in this case NER) tail lamp with a red lens. This is white and on the Dyno car in the NRM, but the body would have been vermillion until about 1938.
- greenglade
Re: lamp colours
I have been told that for the loco tender (when running light) the lamps would be white with the rear having a red lens....Would I be correct in thinking that the red-bodied lamps were only on the rear of passenger trains and fixed by the guard? Loco crew having just the two lamps both white bodied?
cheers
Pete
cheers
Pete
Re: lamp colours
That is about it. The red lamps were placed by the guard, and up until about 1923 each brake end also carried two red riding lights, one each side over the ducket. This can still be seen on the Royal Train brake in the NRM, where the riding lights were found to be red when restoration took place in 1976.
Light locos were supposed to display one white light over the centre of the buffer beam and one red aspect to the rear; with corridor tenders this could be either side since there was no centre iron!
- greenglade
Re: lamp colours
Thank you....I'm begining to get the picture..
Many thanks
Pete
Many thanks
Pete
