V2 monoblock cylinder castings
drmditch
Post by drmditch »
If this is discussed elsewhere on this forum please forgive me.
F A S Brown in his biography of Gresley, and Dr Geoffrey Hughes in his ''The Gresley Influence' state that the V2 cylinder/valve chest/steampipe/smokebox saddle casting was steel.
I have not found any other reference to this. RCTS 2A says that the cylinder castings for the A1/A3s were iron, and I haven't found (yet) any reference as to what the A4s used.
I think I have also seen somewhere a reference to the V2 castings being a product of Gorton, but can't locate it at the moment.
As a linked question, were the P2 cylinder blocks iron or steel?
Re: V2 monoblock cylinder castings
The LNER specification reproduced in the NRM's 'Gresley and Stanier' has 'Cylinders...cast-iron to LNER specification no 14'.
drmditch
Post by drmditch »
Hatfield Shed wrote: Mon Sep 10, 2018 5:17 pm The LNER specification reproduced in the NRM's 'Gresley and Stanier' has 'Cylinders...cast-iron to LNER specification no 14'.
Thank you. I haven't got that book. To which locomotive(s) does that specification refer?
drmditch wrote: Mon Sep 10, 2018 5:28 pm Thank you. I haven't got that book. To which locomotive(s) does that specification refer?
Specifically the V2. The book was a chance s/h 'giveaway priced' find in a charity shop. Seemed rude to leave it behind.
greenglade
Post by greenglade »
In 'LNER Locomotive Development' by Jim Armstrong when describing the first V2 it states when describing the differences between the new V2 and A1/3's....quote: 'A completely new front end was designed, having the three-cylinders, steam chests and smokebox saddle cast in one huge block of steel' end quote:
IIRC the norm for cylinders at the time being cast iron with it's self-lubricating capability, same as internal combustion engines. Perhaps casting such a large lump in iron proved too problematic? The reasons may be out there somewhere..
Pete
drmditch
Post by drmditch »
Thank you. But wouldn't the casting (of whatever material) have had cast-iron cylinder sleeves fitted?
(Even more important in such an expensive casting.)
greenglade
certainly, for the valves, that's normal practice for iron cylinders...I would guess for the main bore too...having not researched it I'm surmising...
Eightpot
Post by Eightpot »
Steel as used for castings doesn't 'flow' very well whereas iron does. These days probably Spheroid Graphite iron (known as SG iron) would be a better bet as it casts like iron with similar wearing properties, but has the near strength of steel.
