Atso's new loco works - now including my Hadley Wood layout build
Re: Atso's new loco works - now including my Hadley Wood layout build
(Continued from the previous page) I have been tinkering with the C1 as well during periods where I've been waiting for paint/glue to dry on other things. Still a way to go yet but here is a picture of it in its current condition.
To answer the earlier question about the brass rod, they are split pins to allow an electrical connection between the loco and the tender for pickup.
I've also been slowly designing this over the last few months to make use of the Peco spare parts from their Collett goods locomotive that were obtained by Peter's Spares earlier this year - apologies for the terrible focus!
This one will eventually be a representation of Hitchin based J3 no. 4011. I would have liked to have modelled one of the Kings Cross based locomotives but, so far, photographs of these locomotives have proven elusive and the class is a bit of a minefield. I have plans to model a second Hitchin locomotive, 4154 which differs in the location and number of sandboxes among other things.
I'm currently on the lookout for some drawings of a Stirling 'class D' tender as I don't seem to have a set and the majority of the class seemed to have these attached (including 4011 and 4154) rather than the class B and C Ivatt types. Any help on this front would be most gratefully received.
I continue to be impressed by your achievements in such a small scale.
The Atlantic, looks brilliant, and now a J3, Christmas is definitely coming
That's reminded me that I was going to send over the second lot of various drawings (A conversation at Ally Pally)Atso wrote: ↑Tue Dec 18, 2018 7:35 pm I'm currently on the lookout for some drawings of a Stirling 'class D' tender as I don't seem to have a set and the majority of the class seemed to have these attached (including 4011 and 4154) rather than the class B and C Ivatt types. Any help on this front would be most gratefully received.
I'll sort them out for you.
Thank you gentlemen. Some parts for the J3 were included in my Christmas list Manna so hopefully next week will be kind to the loco!
Dave, that is most kind of you. You might really save my 'bacon'!
Suddenly there were two J3s (and some backheads).
Hopefully, the above picture demonstrates some of the differences between members of the class. Getting sufficient clearances to allow the wheels to turn freely without compromising on the dimensions too much was 'interesting'.
I did toy briefly with trying to make the loco chassis powered with the motor in the tender. However, I decided that getting sufficient weight over the driving wheels would be problematic at best and copped out. The drive will be supplied by a much modified Union Mills tender drive fitted with (more or less) scale wheels and a replacement 716 low revving coreless motor.
If I'm lucky, 4154's wheels will be available tomorrow and if I have (am allowed ) time, I'll assemble the loco.
Very nicely done.
Thank you Graeme.
Will you be making the trip to Stevenage next month? If so I'll bring them along for you and 'Red Leader' to have a look at - and point out all the bits I've got wrong!
Merry Christmas one and all!
Do you think they'll convert to 2 mm ?????
Possibly with some work to the body and a new chassis, but I won't be trying! As tempting as 2mm finescale is, I have far too much stock (and far too little money) to viably consider rewheeling everything. However by using Finetrax's kits some code 40 track work of a similar look to 2mm scale can be employed and that is the compromise I'll have to live with - also I can retain a 12 minimum radius curve (in the hidden areas) which would be much more difficult in the finer scale.
Christmas provided another set of wheels and coupling rods and so these were assembled and the parts for J3 no. 4154 were fettled before the locomotive was assembled. Now there are two locomotives on wheels (minus tenders).
St Evenage next month is in my diary, in ink. See you there.
Great, see you there!Atlantic 3279 wrote: ↑Thu Dec 27, 2018 11:07 am St Evenage next month is in my diary, in ink. See you there.
J3s are now as detailed as I wish to make them before painting.
I like to leave items such as buffers off at this stage as it makes painting the buffer beams easier (besides I need to order some more!).
Love to see Hornby announce a J3, on the 7th..........
Preferably at a price that nobody will want to pay, featuring something that is obviously wrong (even if only a minor feature), with about twelve wires connecting loco to tender via a tight-fitting and very fiddly plug (without which the loco alone will not run) and incorporating a mechanism design that won't go into the outline of any other loco, no matter how closely related to the J3.
