Wagon i.d.
burnie
NER J27 0-6-0
Wagon i.d.
Post by burnie » Wed Jan 16, 2019 7:10 pm
In 1952 a wagon left Inverkeilor station yard with 50 sacks of barley on board on it's way to Oswestry, the number was E1Y6151, any one able to identify what type of wagon this would have been?
Thanks
Re: Wagon i.d.
Post by jwealleans » Thu Jan 17, 2019 7:54 am
That number is incorrect - the wagon would have been 'Ennnnnn'. Maybe a 7?
Sheeted open or a van would be a guess based on the load - I'm sure someone will have the time to look through Tatlow and see what they can find.
Do you have the label for this load?
burnie
NER J27 0-6-0
Re: Wagon i.d.
Post by burnie » Thu Jan 17, 2019 11:05 am
This was sent to me, I don't have the label myself
Re: Wagon i.d.
Post by Dave » Thu Jan 17, 2019 11:21 am
I read that as E176151, and the label says it's a van, which narrows it down a bit, I will look at my numbers.
Re: Wagon i.d.
Post by Dave » Thu Jan 17, 2019 11:31 am
Right found my numbers, lucky I had a copy at work.
If my interpretation of the number is correct then the wagon lies in the number series 175829 to 176328, a LNER covered goods van to Dia 25,
part of an order of 500 built in 1934.
Hope that helps.
burnie
NER J27 0-6-0
Re: Wagon i.d.
Post by burnie » Thu Jan 17, 2019 11:42 am
Thanks Dave, I am contemplating making a model of Inverkeilor station in this period in OO scale and thought it would be nice to include this van in the yard.
richard
Re: Wagon i.d.
Post by richard » Thu Jan 17, 2019 7:34 pm
Although there aren't any other 7s to compare, I agree with the interpretation - if that helps!
Those sorts of u-topped 7s seem more common in the past.
burnie
NER J27 0-6-0
Re: Wagon i.d.
Post by burnie » Fri Jan 18, 2019 12:47 pm
Seems I need one of these then(or two or three maybe)
https://peco-uk.com/products/lner-bulk-grain-wagon-1931
Re: Wagon i.d.
Post by jwealleans » Fri Jan 18, 2019 3:32 pm
That says Diagram 23, not 25. I'm also fairly certain that there were nowhere near 500 built. 50 seems nearer the mark.
Darryl Tooley
Re: Wagon i.d.
Post by Darryl Tooley » Fri Jan 18, 2019 3:55 pm
The buik grain wagons were originally built to carry imported grain from Hull. I'd be surprised if Inverkellor ever had the requisite facilities and volume of traffic for their use. I stand to be corrected.
Also, that kit's a pig.
D
burnie
NER J27 0-6-0
Re: Wagon i.d.
Post by burnie » Fri Jan 18, 2019 5:00 pm
That's what you get when you ask modelers for advice, I shall keep looking then.
Re: Wagon i.d.
Post by jwealleans » Fri Jan 18, 2019 5:04 pm
Isn't one of the Bachmann LNER vans a Diagram 25?
Re: Wagon i.d.
Post by Dave » Fri Jan 18, 2019 5:12 pm
Burnie, this is a Dia 25 van
burnie
NER J27 0-6-0
Re: Wagon i.d.
Post by burnie » Fri Jan 18, 2019 5:57 pm
Thanks Dave
65447
Re: Wagon i.d.
Post by 65447 » Fri Jan 18, 2019 7:17 pm
Make sure it has a steel underframe (not wooden) and 10' wheelbase (not 9') and is fitted with the vacuum brake - all as Dave's photograph.
