Robinson anticipated our needs, all those years ago.
Looking really nice Tim, can't wait to see the paint job.
Interesting new kind of self trimming part too.
- nzpaul
I think I'll go and set fire to my work bench....
That's really remarkable.
As promised some time ago, the styrene back head pattern was sacrificed to make a metal substitute, using investment casting.
The pattern was mounted on a casting cone with wax, sprued into the back of the pattern in a non critical area and angled to give optimal metal flow.
A cristobalite investment was used.
The casting ring is lined with an aluminio-silicate tape to allow expansion of the investment on heating.
The vacuum mixed investment slurry is poured into the ring taking care to avoid air bubbles on the pattern.
The cone former is removed and the ring then placed in a furnace at 600 deg C to burn out the styrene and wax pattern. This also expands the investment to compensate for the shrinkage of the cooling alloy.
The metal used is a high copper (80%) brass alloy - “students alloy”. It has a liquidus at 1015 deg C and is heated in an induction furnace.
The cast button can be seen and, once cool, it is then broken out of the ring.
The moment of truth is when the casting is divested using grit blasting.
The sprue was cut off and then the casting polished with glass bead blasting. It is a amazing how the casting picks up all the faults in the original pattern!
There will be some extra details added to the back head casting such as the firebox door and seat backs. Apologies for the rather long post, but I thought it might be of interest to see some of the technical aspects of ‘lost wax’ casting.
Tim
Tim
It was very interesting.
I wasn’t originally going to make the signal work, but it seemed a shame not to.
https://youtu.be/2DIW4LYRZdg
The operating mechanism should prevent any interference between the arm movements.
Tim
Tim
The BI Up Home gantry is now pretty well complete, apart from bedding in and connecting up the mechanisms. The secret of making the linkages work was to chemically black the cranks so that they could not be soldered up. Another useful dodge was to make the dolls out of square brass tube: that way they didn’t act as a massive heat sink when soldering nearby. The railing stanchions were trimmed to length in situ using a bit of brass tube as a cutting guide for the Xuron cutters. All the rails and wires were made from phosphor bronze wire, as it has more resilience than brass or nickel silver.
The finials were filed up from a Peco track pin and buried down the hollow post, with a separate piece of syringe needle fettled into shape for the round bit. All of these bits were epoxied into place.
The final bedding in will have some fixings modelled on the retaining wall and a plastic ladder glued into place: these are more robust than etched ladders.
The video shows the signals working by hand on the baseboard. It may be a little while before we connect up actuator servos. These will be operated by the passing trains
https://youtu.be/mPHxJPS-ZNw
Tim
Tim
G'Day Gent's
I can remember those days at Kings Cross when it was so hot on the footplate, and thinking the 'bobbie's' had it so good, door's wide open, windows all open and a breeze, I know we had window's, but we had a Thumping Great diesel engine only a few feet away pumping out so much heat.
Lovely models, though.
Goodbye old friend.
When we started surveying Belle Isle to make CF in 1983, the Ebonite Tower still existed: it was demolished soon after. Ebonite was a hard vulcanised rubber. The tower was a feature in the background of many of the classic railway photos of the 1950s & 60s.
However, not long ago, we discovered that up until 1955 (a very good year) it had been the works of Tylors, who made hydraulic and sanitary ware products. The tower acted as a chimney and also supported a water tank for pressure testing their products.
The company moved away from KX to south of the river. Interestingly, we have ‘Tyler’s Sanitary Ware’ products advertised on some of the lower buildings (clearly mis-spelt Tyler- soon to be corrected).
Some artwork was made up using PowerPoint, saved as a photo, re-imported to PowerPoint and stretched vertically to make the font fit the required dimensions. The colour is conjecture, but blue seemed appropriate for hydraulic equipment.
The tower itself was mocked up many years ago by Mike Randall from a lump of mahogany. He has subsequently made some laser-cut & etched sides for it which were fitted a couple of years ago.
Loosing the Ebonite Tower is the end of an era - wonder how long it will take for the new name to catch on.
Tim
Tim
G'day Gents
Absolute icon, I didn't know it had been demolished.
