Which carrier did you use? Royal Mail have lost mine.
TMC G5
Re: TMC G5
Mine did come by Royal Mail, with no delay and visible on their tracking tool all the time.
Re: TMC G5
I had a little fiddling time to alter the bogie mounting for about 5 degrees of rotation on the bogie centre. Rear of loco stays centred on the track, negotiates my 30" (centreline) minimum radius requirement.
I might radically alter the arrangement if I ever take this loco for a visit to a friend with a 24" ruling radius layout, but that will require rather more chopping, and subsitution of wiring for the present wiper transfer to conduct track power from the bogie frame to the driving wheel pick up strips.
As a comparison, placed order 15.15, DPD were knocking on my door 08.55 the following morning. The starting location is part of the problem for RM; we have relatives not far away on the NY moors, and it's three days for post from there in our experience.
Re: TMC G5
Mine was despatched on the NYM at 18:09 last Monday, was at Warrington at 15:24 on Tuesday and at Chester some 4 hours later, at 19:36. It hasn"t been seen since and the tracker is still showing 'in transit' a week later.
Re: TMC G5
Well, even out here in the Southern Hemisphere, my G5 arrived 2 days ago. Lovely looking model although I am not as knowledgeable about some of the shortcomings on detail mentioned by other posts.
The only thing I have noticed is that it seems to be very slow on starting and similarly slowing down, requiring more care when pulling into a station. No doubt only a matter of adjusting the relevant CV and all will be well.
What I'm sure other NER modellers would like to have is a selection of early clerestory carriages, of which there are many photos of G5s working them.
Graeme Leary
New Zealand
Graeme Leary
New Zealand
Re: TMC G5
Latest
The tracker woke up yesterday to say the parcel was back at Warrington at 16:54 and at Chester again at 00:04. The postman has just been at 15:45 Friday with the contents seemingly intact. He knocked in the door and by the time I could open the door, he'd gone, van and all, leaving the parcel on the step for anyone to help themselves to.
Question is where has it been hiding for 9 days? The packaging doesn't seem to have been tampered with and for something 18"x7"x7", you could hardly miss it.
Re: TMC G5
What do you make of this G5 roof. TMC don't know?
Re: TMC G5
Don't know about the roof but isn't the number a big high? Shouldn't it be central?
Re: TMC G5
What about the pristine cream colour inside the cab? Anyone got inside yet to paint it grubby grey brown? I haven't fiddled with body work at all yet so any knowledge of which construction screws enable access would be useful.
I was curious about the four upstands, one in each corner and wondered if they were securing points for tarps in time of inclement weather. Apparently they are tank vents.
It's a roof.
Never looked at BR standards for postioning these; but as seen on BR's locos there was plenty of variation for no clearly apparent reason. I have 67342, and there is a good photo of 67343 in the same livery scheme in 'Eastern Region in Colour', which has totem and number probably vertically centred in the panels defined by the lining. 'Probably' because the top of bunker panel lining is obscured by dirt.
Re: TMC G5
Tank Vents
Re: TMC G5
I received my LNER 1752 on Wed. On studying photos I've noticed the the second pipe on the buffer beam (the pipe further from the hook) which is meant to be a Westinghouse pipe is nothing like the right sort of pipe and is in the wrong position. It should be the opposite side of the coupling hook to the vacuum pipe.
Also on the bunker the vacuum pipe is the wrong side of the coupling hook. Again I dispensed withe the second incorrect pipe.
In the mid 30s Westinghouse pipes, according to Yeadon were moved to below the buffer beam so that's what I've done on mine using a suitable pipe from my spares drawer. I've also fitted a more appropriate thicker steam heating pipe below the front buffer beam.
On the bunker I've removed both pipes and replaced the vacuum pipe with a taller version to the right of the hook looking at the bunker in accordance with photos. I've not added a Westinghouse pipe as I need clearance for the tension lock coupling- which I've shortened.
The lettering appears to me to be almost gold but on comparison with my recent Bachmann V2 it's not gold. It's a rather faded yellow though but is very good apart from the colour.
- LNER N2 0-6-2T
Re: TMC G5
A buffer fell off front and back apparently during transit, a minor annoyance but nevertheless a quality issue.
