Now running out of complimentary words of praise of your work on YR Tim.
Thanks Stevie. Not really LNER, but physically very close! The upper works are nearing completion, will start soon on the heavy engineering for the lift.
Tim
Tim
.... Could be a 1920s/30s photo of the real thing Tim Watson !
After nearly six months solid work, the YR station is now complete above ground, and has a passing resemblance to the prototype.
(Courtesy LTM archives)
The open areas at the back now have polycarbonate covers to protect against little fingers. Next job, on this project, will be making the stair, lift and ventilation shafts.
Tim
Tim
Top job. I've run out superlative's to.
So have I manna !
.... Just amazing Tim Watson.
I bet the plumbing works as well.....
Wibble!
Stunningly good...
Handsome, and some.
Beautiful!
I need to get my 4mm one started!
Baz
Baz
A real delight - and something of a change to see a pre-group model in non-pristine finish.
Beautiful work !!!
