Express Headlamps and Tail-lights
Next stage of my express project is fitting loco headlamps and taillights to The Flying Scotsman (Express) and in the not too distant future (I hope) The West Riding Pullman.
I know there were quite definite rules to indicate a wide range of different train types (on the locos) and I presume set tail-lamp positions. (Another train type would be a long coal train and mixed goods - non- stopping if relevant - as I also run these frequently as well as a 2 coach rural suburban train).
Any help gratefully accepted on all these train types but particularly the FS and WRP expresses.
Graeme Leary
Graeme Leary
- LNER N2 0-6-2T
- Location: White Rose County Gresley & Peppercorn Country
Re: Express Headlamps and Tail-lights
Graeme Leary wrote:Next stage of my express project is fitting loco headlamps and taillights to The Flying Scotsman (Express) and in the not too distant future (I hope) The West Riding Pullman.
That is something I would like to now as well.
DonnyRailMan Instagram @severncrescentrailway
Graeme
You will find diagrammatic lists in several places on the internet but in simple terms for the expresses mentioned the head codes (white single lamps in each case) would be:
o - o
The tail lamp would be a single red (up until 1937) and then white lamp normally set on the Pullman gangway. The only express passenger trains to have two lamps were the SJ and Coronation/WR sets.
Nick
o - o
Nick
- strang steel
This web site should help -
http://myweb.tiscali.co.uk/gansg/3-sigs/bellhead.htm
Scroll down a little for the loco lamp codes.
- LNER N2 0-6-2T
Thanks for link, it was the tail-lights I was not sure about.strang steel wrote:This web site should help -
G'day Gents
As far as I know, the tail lamp, was usually put on the side closest to the platform.
Sorry, Nick, have I misunderstood here? Do you mean that the lamp showed white or (as I assume) that it was painted white?The tail lamp would be a single red (up until 1937) and then white lamp normally set on the Pullman gangway.
I didn't know or had forgotten that carriage tail lamps were painted red. So in 1935-39 (the era of Grantham) we'd be likely to see a mixture of both.
Brake van lamps were black throughout the LNER period, is that correct?
Jonathan
That was a bit stupid of me! The lamps were painted red up until everyone started to get a rush of blood about air raid precautions and then changed to white (I think the same applied to the other three members of the big four); however the lamp showed a red aspect in each case. The goods brake side lights were black with the appropriate colour aspect as dictated by running lines, but the tail lamps, usually one centrally, were on the same basis as the passenger lamps.
I would agree that tail lamps tended to be positioned (or rather placed) on the side nearest the platform, but then I can think of quite a few instances where this could have been either side!
Just to complete the picture, the small riding lights used on passenger brakes before 1923 were usually red, viz the Royal Train Brake in the NRM.
Nick
Nick
Which reminds me that I still have a couple of goods brakes with side lamps wrongly painted red. I must underline that job on the "to do" list....
Greetings all and many thanks (and apologies for delayed reply - blasted computer 'locked'). Very helpful and in particular the link to Bell Codes and Locomotive Head Codes - and will also be adding Classes E, F & H to my repertroire of goods trains. Brilliant!
Graeme
Graeme
