V2 monoblock cylinder castings
drmditch
LNER P2 2-8-2
Post by drmditch » Mon Sep 10, 2018 11:26 am
If this is discussed elsewhere on this forum please forgive me.
F A S Brown in his biography of Gresley, and Dr Geoffrey Hughes in his ''The Gresley Influence' state that the V2 cylinder/valve chest/steampipe/smokebox saddle casting was steel.
I have not found any other reference to this. RCTS 2A says that the cylinder castings for the A1/A3s were iron, and I haven't found (yet) any reference as to what the A4s used.
I think I have also seen somewhere a reference to the V2 castings being a product of Gorton, but can't locate it at the moment.
As a linked question, were the P2 cylinder blocks iron or steel?
Re: V2 monoblock cylinder castings
Post by Hatfield Shed » Mon Sep 10, 2018 5:17 pm
The LNER specification reproduced in the NRM's 'Gresley and Stanier' has 'Cylinders...cast-iron to LNER specification no 14'.
drmditch
LNER P2 2-8-2
Post by drmditch » Mon Sep 10, 2018 5:28 pm
Thank you. I haven't got that book. To which locomotive(s) does that specification refer?
Post by Hatfield Shed » Tue Sep 11, 2018 8:15 am
Specifically the V2. The book was a chance s/h 'giveaway priced' find in a charity shop. Seemed rude to leave it behind.
greenglade
Post by greenglade » Tue Sep 11, 2018 10:51 am
In 'LNER Locomotive Development' by Jim Armstrong when describing the first V2 it states when describing the differences between the new V2 and A1/3's....quote: 'A completely new front end was designed, having the three-cylinders, steam chests and smokebox saddle cast in one huge block of steel' end quote:
IIRC the norm for cylinders at the time being cast iron with it's self-lubricating capability, same as internal combustion engines. Perhaps casting such a large lump in iron proved too problematic? The reasons may be out there somewhere..
Pete
drmditch
LNER P2 2-8-2
Post by drmditch » Tue Sep 11, 2018 11:08 am
Thank you. But wouldn't the casting (of whatever material) have had cast-iron cylinder sleeves fitted?
(Even more important in such an expensive casting.)
greenglade
Post by greenglade » Tue Sep 11, 2018 11:20 am
certainly, for the valves, that's normal practice for iron cylinders...I would guess for the main bore too...having not researched it I'm surmising...
Eightpot
Post by Eightpot » Sun Sep 23, 2018 1:31 pm
Steel as used for castings doesn't 'flow' very well whereas iron does. These days probably Spheroid Graphite iron (known as SG iron) would be a better bet as it casts like iron with similar wearing properties, but has the near strength of steel.
