000 Gauge
Moderators: 52D, Saint Johnstoun, richard, Tom F, Rlangham, Atlantic 3279, Blink Bonny
Iron Duke
000 Gauge
Post by Iron Duke »
Found this little book (90 pages) in my Fathers loft, does anyone still model in this scale?
Not knowing very much about the history of modelling myself, was this the forerunner of N?
ID
2512silverfox
Re: 000 Gauge
Post by 2512silverfox »
I thought this had been replaced by 'N' gauge which is 2mm:ft. Have not heard it called 000 since the 50s?
Atso
Re: 000 Gauge
Post by Atso »
Hi Iron Duke,
My understanding is that OOO was indeed the forerunner of N gauge. In fact, I believe that the basic standards are actually what was developed into what we now know as 2mm finescale. Don't quote me on that though!
Coboman
Re: 000 Gauge
Post by Coboman »
Lonestar stuff was OOO if I remember correctly
All thumbs
H&BR Q10 0-8-0
Re: 000 Gauge
Post by All thumbs »
I had some Lone Star push-along bits in the early 1960s and remember it being called 000 or Treble-0. There was an A4 in garter blue among the various locomotive models available. I can also remember Treble-0-Lectric arriving but as I already had some Tri-ang 00, I wasn't tempted (and my pocket money wouldn't have stretched to it anyway).
BTW is that coin a sixpence or even a silver thrupenny? It's clearly George VI which surely dates Carter's booklet to 1953 or earlier...
StevieG
Re: 000 Gauge
Post by StevieG »
So did I. I also remember Lone Star push-alongs including an LMS Duchess/Princess class IIRC, and a 'jinty', and a single-cab N. American diesel, plus UK and N.Am. bogie express passenger coaches, and some four wheel goods wagons of one or two types.
Track came in grey, with straight and curve sections, plus Left & Right points, diamond crossings, all cast with their own ballast formation, and sand-filled timber stockade-type buffer stops. All parts just hooked together by an offset hook/lug and corresponding slot at each end, but needed a level surface to line up properly.
The coin in the picture is a bit dark but I reckon it's a sixpence, roughly 1/2-inch (13mm) in diameter, about the size of the old 1/2p coin.
micknich2003
H&BR Q10 0-8-0
Re: 000 Gauge
Post by micknich2003 »
For some reason "000" gauge was dropped and it became "2mm". I asked a 2mm asoc member why, and I was given, what to me was a pointless answer or reason. If it's not broke don't fix it.
I presume the bloke on the cover of your book is E. F. Carter an incredable man who did a lot for the hobby. Note how the picture is cropped, I'm almost certain, he only had one arm. Mick.
Intrested in signalling, P Way, loco's and most railway subjects. Keen model maker etc. presently aiming to model part of Hull, Springhead yard etc.
Horsetan
NER C7 4-4-2
Re: 000 Gauge
Post by Horsetan »
All thumbs wrote:I had some Lone Star push-along bits in the early 1960s and remember it being called 000 or Treble-0........
....and there was Treble-O-Lectric....
strang steel
Re: 000 Gauge
Post by strang steel »
StevieG wrote:So did I. I also remember Lone Star push-alongs including an LMS Duchess/Princess class IIRC, and a 'jinty', and a single-cab N. American diesel, plus UK and N.Am. bogie express passenger coaches, and some four wheel goods wagons of one or two types.
I have still got some push along Lone Star railway bits and pieces, somewhere in a box up the darkest recesses of the loft.
It has not seen the light of day for well over 30 years, but I remember an A4 and a 2-6-2T and a diesel shunter not unlike an 08. There was even a representation of a Mk1 coach in sort of red/maroon colour. I used to lay out my track on the living room carpet and spend many hours pushing the trains along. The advantages were that it was easy to change the layout and run any combination of locos I liked.
I even used to have a "SR emu" day, when I just pushed the carriages to and from the station and only used locos for goods trains. How sad is that?
Blink Bonny
Re: 000 Gauge
Post by Blink Bonny »
I often wonder why it didn't take off. Maybe thee market was not ready for it at the time. Certainly N took off big time in the late 1960s.
Incidentally, OOO and N are different. N is a smidgeon over (GB) or under (ROW) than 2mm and runds on 9mm gauge track. 2mm FS runs on 9.42mm gauge. What was the gauge of OO?
There is a much modified Lone Star A4 running on Copenhagen Fields!
DaveF
Re: 000 Gauge
Post by DaveF »
I think the term "n" gauge was adopted to bring us into line with European manufacturers, I am sure I remember an article by C J Freezer in Railway Modeller in the 60s (?) explaining the rationale, part of which that the track gauge was 9mm, in most languages the word for 9 begins with n. Remember at this time Minitrix and Peco were producing things for the British market along witrh a few kit manufacturers so it made sense to have one name for import/export reasons.
Commercially produced 000, for example the Lone Star range, including their electric models could not be described as 2mm scale. Just think of the wheel standards (and the track gauge).
000 was never really a synonym for n or 2 mm scale in general use..
David
You may enjoy my photos which have now moved to flickr from the sadly missed fotopic.
They can be found at: http://www.flickr.com/photos/davidwf2009/
StevieG
Re: 000 Gauge
Post by StevieG »
Many thanks for the 'treble-O-Lectric' website Horsetan. A gem of a find! And what a range! - Amazing.
It's reminded me that I had other accessories that I'd forgotten about : the bridge and incline piers, signal box, signals, level crossing barriers.
Thanks for that SS.
I'd forgotten that I also had the 2-6-2T and the '08'.
Sad? - I remember once setting up a layout that looked like the whole Metropolitan line as seen on the Underground map, but only single-track of course (with the the two routes at Whitechapel that are in reality on different levels, being just a diamond crossing :lol: ), and in the same way pushing passenger coaches on journeys such as to/from 'Amersham' to 'Aldgate', 'Hammersmith - 'Barking', and 'Shoreditch - (alternately) 'New Cross' & 'New Cross Gate'! Now that's sad!!
Beechwood
Re: 000 Gauge
Post by Beechwood »
The layout on the cover is the Inversnecky and Drambuie, which still exists as a static exhibit in the NRM - in the warehouse part.
PGBerrie
Re: 000 Gauge
Post by PGBerrie »
Beechwood wrote:The layout on the cover is the Inversnecky and Drambuie, which still exists as a static exhibit in the NRM - in the warehouse part.
More here http://www.2mm.org.uk/layouts/inversnec ... snecky.htm.
Peter
strang steel
Re: 000 Gauge
StevieG wrote:Many thanks for the 'treble-O-Lectric' website Horsetan. A gem of a find! And what a range! - Amazing.
Yes, me too. If I remember properly the piece of track used with the level crossing was also a useful re-railer.
