nzpaul
Post by nzpaul »
Wow, lovely. I don't know what else to say. Stunning locos.
52D
Post by 52D »
jwealleans wrote:Lovely. The forum always benefits from work of that quality.
Hear hear JW
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
The GNR Brake Van is now in paint awaiting some weathering:
Very neat indeed.
A couple of questions though: How widespread was the practice, according to date, of painting brake van handrails white? Were side riding lamp bodies ever red? I ask the latter because I instinctively painted some red but later information suggested to me that they were black.
From memory - so treat with caution - riding lamps on passenger brakes were red for a time early in the LNER period but then went either black or body colour. Brake van lamps I thought were black.
What red oxide paint have you used? It comes up very brown on my monitor. Tidy job, though.
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
I did wonder what colour the lamps were, on these vans they were fixed bodies if i understand it right and a lamp was put in from inside.
Not sure on the handrails either but once weathered they won't be so obvious.
The paint was a mixture of Railmatch LNER oxide and some sleeper grime i had laying around.
Will paint the lamp bodies black later tonight so thank you for the info folks.
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
Got a quick job on it's a Mousa Models GCR D.7 Dropside wagon
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
Got some work done last night:
1. Rivets punched out in the outer shell.
2. Outer shell folded and Soldered:
3. Inner shell folded and soldered alongside the outer:
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
Inner and outer shells soldered together:
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
Inner Solebars added and the outer cosmetic ones have already had the rivets punched out:
Cosmetic (outer) Solebars added and the first of the end stanchions side already folded up:
All 4 end stanchions sides added, the front faces now need to be folded up and added, this is a very long winded way of doing things and i would normally have used white metal castings:
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
End stachions complete and buffer bodies added:
First set of wheels and axle boxes added:
Both wheelsets now fitted:
Brakes started to be added:
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
All Brake gear added:
Buffers added and now in grey:
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
Transfers on, will need to weather it down now:
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
Now Weathered:
GNR Brake van also toned down:
Rustynuts
LNER J39 0-6-0
Post by Rustynuts »
On with the next wagon build, this time a Mousa Models GCR D.19 5 Plank coal wagon, so here is the result of the first evenings work:
