Wagon i.d.
Wagon i.d.
In 1952 a wagon left Inverkeilor station yard with 50 sacks of barley on board on it's way to Oswestry, the number was E1Y6151, any one able to identify what type of wagon this would have been?
Thanks
Thanks
Re: Wagon i.d.
That number is incorrect - the wagon would have been 'Ennnnnn'. Maybe a 7?
Sheeted open or a van would be a guess based on the load - I'm sure someone will have the time to look through Tatlow and see what they can find.
Do you have the label for this load?
Re: Wagon i.d.
This was sent to me, I don't have the label myself
Re: Wagon i.d.
I read that as E176151, and the label says it's a van, which narrows it down a bit, I will look at my numbers.
Re: Wagon i.d.
Right found my numbers, lucky I had a copy at work.
If my interpretation of the number is correct then the wagon lies in the number series 175829 to 176328, a LNER covered goods van to Dia 25,
part of an order of 500 built in 1934.
Hope that helps.
Hope that helps.
Re: Wagon i.d.
Thanks Dave, I am contemplating making a model of Inverkeilor station in this period in OO scale and thought it would be nice to include this van in the yard.
- richard
Re: Wagon i.d.
Although there aren't any other 7s to compare, I agree with the interpretation - if that helps!
Those sorts of u-topped 7s seem more common in the past.
Re: Wagon i.d.
Seems I need one of these then(or two or three maybe)
https://peco-uk.com/products/lner-bulk-grain-wagon-1931
Re: Wagon i.d.
That says Diagram 23, not 25. I'm also fairly certain that there were nowhere near 500 built. 50 seems nearer the mark.
- NBR J36 0-6-0
Re: Wagon i.d.
The buik grain wagons were originally built to carry imported grain from Hull. I'd be surprised if Inverkellor ever had the requisite facilities and volume of traffic for their use. I stand to be corrected.
Also, that kit's a pig.
D
D
Re: Wagon i.d.
That's what you get when you ask modelers for advice, I shall keep looking then.
Re: Wagon i.d.
Isn't one of the Bachmann LNER vans a Diagram 25?
Re: Wagon i.d.
Make sure it has a steel underframe (not wooden) and 10' wheelbase (not 9') and is fitted with the vacuum brake - all as Dave's photograph.
